Author Topic: Try this one  (Read 888 times)
Offline Den
Try this one
« on: January 28, 2016, 20:23 »
Take this test:
Below are four questions. You have to answer them without delay. You can’t take your time; answer all of them immediately.
Ready? GO!!! ………………..First Question:You are participating in a race. You overtake the second person. What position are you in?………………..Answer:If you answered that you are first, then you are wrong! If you overtake the second person and you take his place, you are second!………………..(To answer the second question, don’t take as much time as you took for the first question.)
Second Question:If you overtake the last person, then you are…?………………..Answer: If you answered that you are second to last,then you are wrong again. Tell me, how can you overtake the LAST person?! (You’re not very good at this are you?)………………..Third Question: Very tricky math! Note: This must be done in your head Only. Do NOT use paper and pencil or a calculator. Try it.
Take 1000 and add 40 to it. Now add another 1000. Now add 30. Add another 1000. Now add 20. Now add another 1000. Now add 10. What is the total?………………..Answer:Did you get 5000? The correct answer is actually 4100. Don’t believe it? Check with your calculator! The decimal sequence confuses your brain, which always jumps to the highest decimals (100’s instead of 10’s).
Today is definitely not your day. Maybe you will get the last question right?…………..
…4th Question: Mary’s father has five daughters: Nana, Nene, Nini, Nono. What is the name of the fifth daughter?………………..Answer:Nunu? Nana? Nene? NONO! Of course not. The fifth daughter’s name is Mary. Read the question again.
How did you do?
First in the 2025 Quiz of the Year and once again I beat Clive.
Re: Try this one
« Reply #1 on: January 28, 2016, 21:23 »
 :aarrgh: :bawl:
Re: Try this one
« Reply #2 on: January 29, 2016, 09:11 »
I got the last two right.  :smart:
Re: Try this one
« Reply #3 on: January 29, 2016, 15:17 »
Swot!!
Re: Try this one
« Reply #4 on: January 29, 2016, 17:45 »
 :o:
